Thad Swarfburn III
Sorry if this is flamingly obvious to most of you, but I read somewhere, and must concur, that the best way to clean files is to use a rifle shell casing.
NOTE: Remove bullet using customary method first.
I got a .300 Winchester shell from a coworker, and pressed the noisy end flat in vise. Slide the file-cleaning tool over the file parallel to the angle of the teeth. After a few strokes, the brass will form to the shape of the tooth and dig out all the cruft that's deep down in the V. It's so good that I've never bothered to buy a file card.
Drill and tap the primer end for whatever small diameter long bolt you have around to make it easier to hold.
Warning- the serrated end of this tool does a great impersonation of a razor saw in flesh, so keep your wits about you when using it.
Wish I could give credit for this handy tip, but can't recall where I read it.
Matt
Matt
