cast iron or steel
firebird
Hi
Today at work I had to fit a pair of these wishbones.
The ball joints are worn out but as with a lot of things these days you have to fit the whole thing and throw the rest away. I was just wondering if they are cast iron then some usefull lumps can be cut from them. How do I tell if it is cast iron or steel???
Rich
Firebird
I was going to say try Google for spark test of metals But having seen this on you tube whilst good for showing the sparks, I was not to happy with the gap on the grinding wheel to tool rest
Dave Bick
[ame]http://www.youtube.com/watch?v=O5qFa-ws7vI[/ame]
A better Utube for the question asked
[ame]http://www.youtube.com/watch?v=5R1Y6_g0DU8[/ame]
Hi Rich
I used to work for a company which use to produce these components
(Quinton Hazels) and all the ball joints where made from steel. But i could not tell you what grade of steel is used. Hope this helps a little.
Ken
Yes the balljoint itself is made from steel (with a nylon insert around the ball) but the arm itself can be made from just about anything including aluminium (I have a couple to melt down now). Best do the grind test, its easy enough.
Artie
Look for casting flash around the part. Better yet, look at the parting line (the line where the two halves of the mold or die meet). Casting will typically have a rather wide parting line (1/16"+ maybe), and forging very narrow.
I would bet on forged steel, but no idea what alloy.
Kevin
Hi
Thanks for all the tips gentlemen. I am going to stick it in the band saw this afternoon and cut a lump off and then do a grind test. I'll report back later.
cheers
Rich
firebird said:
Hi
Rich
Hi rich , I have a piece almost the same i think it is steel and i do know it machines very well with a close grain, i have used several pieces over the last few months ( i now have two others) and was very pleased with the results and they cost nothing.
regards coldte
Hi
It is steel I think. I cut a lump off the end and it cuts like steel.
On the grinder.
I'll cut a couple of bits off and chuck it under the bench for another day.
cheers
Rich
