Brazing Paste
cobra428
Hi All,
I hate watching the TV show "How It's Made". To To many ideas. :idea: They where showing how fuel pumps where made (for cars). There was a bunch of tubing going through a plate. The "operator" applied a paste through a hypodermic to the joints. It then went into an oven and ....... the most beautiful brazed joints I ever saw.
What the hay is this stuff? Looks like it would work real good in this hobby. Some paste and a torch and .....fantastic.
Tony
Several of the Model Engineering suppliers over here stock the silver solder paste. Its handy for small jobs but does have a shelf life and is quite expensive.
Jason
hi all
I make up brazing paste as i need it ,using a CLEAN fine file ,held over a sheet of paper, i file down a bit of silver solder then mix fillings with flux .
Regards Rob
RobWilson said:
hi all
Now that is a great idea! woohoo1 woohoo1 woohoo1 Just what I was looking for. This forum is great.
Ron
I use solder paste in my work with surface mount electronic components. Prototyping circuit boards. It had a months shelf life.......But we used it for years! Brazing "stuff" is different, but who knows.
Tony
Thanks All ,
I forgot to say it works great for soldering TCT to Mild steel shanks .the under side of the TCT dose need a bit of a rough up before soldering.
Thanks again Rob
Top class tip Rob, .............. I think the hardest job would be finding a "clean" file ::)
CC
Try borrowing the wife's nail file CC :hDe: :big: :big:
Cheers Rob
I used work for a firm that refurbed turbine blades. A gauze would be spot welded to the aerofoil surface & a paste mix of powdered metal / god knows what would be painted onto the gauze in several layers.
The whole lot would then be fired in a huge vacuum furnace (about £2million's worth) to give a new (rough) surface which could be machined & blended back to the blades original dimensions.
A very, very £profitable business. We used to do a high pressure blade from RR's Trent engine which cost £8k new or £5k refurbed. I never saw any that flew but we had a steady stream of work from navy's & middle eastern power generators.
Rob Wilson, sir;
I'm not trying to get all your secrets, but.. Could your reveal what your flux is made of exactly? If its a commercial brand or a home made mixture? I feel following your example and directions in this area to be wise move on my part.
Thanks for all the help you are providing
Kermit
Hi Kermit
I use a commercial silver solder flux paste or you can mix up a small amount of powder flux with water to a creamy paste and keep it in an air tight container ready for the next time you need it
Regards Rob
Not truly brazing but the flux I used many years ago to solder gold alloys was, I believe, a paste made from borax (sodium borate) mixed with a little bit of water to make a paste. I have seen variants that used petroleum jelly (aka Vaseline) as the medium but I don't know whether the amount of borax was "as much as could be added" or a lesser amount.
To use, heat gently to drive off the water/Vaseline and then heat more intensely to melt the borax and perform the hard (gold) soldering operation. Upon cooling it leaves a glassy coating that can be chipped off.
Needless to say I have not tried silver soldering/bronze brazing using this mixture but it might be worth a try. Certainly readily available & I imagine cheap
