brass valve brass valve body
va4ngo
Senior Member
Melbourne
Hello all,
I have a very basic question regarding a works in progress.
I am building "An unusual steam engine" from plans in Live steam magazina circa 1975 and the drawings call for a brass valve body 1/4" I.D, and a sliding valve with material not specified.
I have made the valve also from brass. Should I have used steel and not brass?
Your help would be appreciated
Phil
Hello Phil,
in a display model which is run only occasionally, you will most likely get away with pairing brass with brass for a sliding valve. Unless you are planning to run the engine on steam for extended periods of time, brass/brass should be fine, particularly when lubricated.
As far as the theory goes, steel/brass or steel/bronze would be better choices. Take a look at a chart of friction coefficients, e.g. http://www.engineeringtoolbox.com/friction-coefficients-d_778.html
Have fun,
Fred
Thanks Fred,
That puts me a little more at ease. Fortunately the sliding valve is a very simple turning excercise and if I intend to run with steam (I haven't in th epast) I will make a new valve. I am not one to enjoy doing a job twice.
Good info in that reference to frictions of various materials.
Phil
