Just a few pointers to your decisions.
The first is that this is a flame licker and any extra friction will stop it running, so don't even think about piston rings.
The other, and I warned you earlier about this, in other posts you raised concerning the same thing, hoping to get some sort of blessing for your decision, is that you have your materials a**se about face.
You should always make your piston out of the softer material if you go for dissimilar materials. It is much easier to replace a piston than a cylinder when they wear.
Jan quoted, I think, a steel cylinder with a CI piston. For your second choice, it must be CI cylinder with a CI piston. Purely on the self lubricating properties of the CI.
Then you asked if it could be made with other materials, and you disregarded all that was told to you by people who have experience of these engines, you went your own way because it looked prettier. Making engines isn't about looking good, it is about getting the right combination of materials together so that it will run. Only after it is running, can you make it more cosmetically acceptable.
How are people supposed to help you when you take no notice of what you are being told by people with lots more experience than yourself.
You might be lucky and get it to run fairly easily, but on the other hand, you might find that you can't get a continuous runner, which is what building an engine like this is all about. Then you will expect us all to give you pointers on how to fix the problems when it doesn't run correctly.
So please, we are trying to help, and there is a lot of experience on this site who CAN help you, but if you choose to go down your own route and not take that advice, then why ask the question in the first place?
Bogs
