Do a Google search on line or inline boring. It is a technique used for large machinery such as front end loaders etc to bore and re-bore for bushings etc.
What size lathe do you have mount the part(s) to the lathe . mount the boring bar between centers and bore that way. you may need to make a jig to help with alignment and repeatability.
I would machine the holes to 1.125 to 1.25 before assembly.
make one edge straight and use that as your reference plane or line.
Or use you center hole as a reference. may work better.
You will need some room to do this. Like 24" of z axis.
is this for a model project ?? Kind of big.
Hello Tin and everyone,
thank You for a lot of ideas.
I have a 15x40 lathe, but I don't like to use it for this job. I think I am better off with the horiz. mill and a long boring bar. I can machine both set of bores in one setup, so they should be parallel.
And the mill has external support bearing, IMO it's better suited for this than a lathe. Wish I had a horiz. boring mill with rotary table
Just have to make a long MT5 boring bar.
My projects are usually a bit bigger, one reason prob that among some friends who do metalwork, I got the larger machines.
These parts are going to become truck frames for a garden railway a friend of mine is building. They will look a bit more complicated than the sketch but in the sketch you see everything that has to be machined with some precision.
The railway will use a gas engine now, maybe later a steamer...?
I know no one except from internet who has built such a large steam locomotive, so I expect problems with it
Okay, think I am going to do it with a long boring bar and the h-mill in one setup.
Thanks for your ideas.
Mike
