oldboatguy
- Sep 16, 2008
- 22
- 2
Back in a former career, I worked for a company called Leitelt Iron Works. They used to build and repair boilers as well as mill engines in the distant past. In the course of our boiler service work, we were contracted by an insurance company to forensically dismantle and remove from the property, a heating boiler which had exploded. By forensically, I mean we had to work with the State inspectors and insurance adjusters to identify the reasons for failure and preserve the affected materials as evidence for the ensuing lawsuits.
The heating boiler in question was a "Scotch" type horizontal firetube boiler which was oil fired. The boiler pressure vessel was riveted plate and was approx. 7' in diameter by 16' long. There were approx. 120 2" diameter firetubes reaching from the firebox to the smokebox.
The reason the boiler failed is as follows: The low water cut-off switch had been tampered with by the building superintendant because it had been "nuisance tripping". With the switch jumpered, the boiler continued to fire well after the water level had dropped below the crownsheet level. This caused failure of most of the crownsheet stay bolts and allowed the crownsheet to rupture. This also allowed the firebox tubesheet to rupture into the firebox end of the boiler. The steam violently exhausted from the upper portion of the boiler thru the firebox end, causing the entire boiler to literally become a horizontal rocket.
The boiler was located in the basement of a 70 year old storefront building in Detroit. When it uprooted itself and began to move, it went entirely accross that basement and did not stop moving until it had penetrated thruogh five masonry walls each about 18" thick and fetched up in the basement of the sixth building to the south. The other basements were being used for various shops so numerous people were present when the boiler went.
Sadly, there were 5 fatalities and over 20 serious injuries due to scalding and crushing. We arrived to work on the scene a day after the explosion happened. That was over 30 years ago, but I will never forget looking through those 5 holes in the walls and seeing that crumpled boiler about 160 feet away from where it had started.
The point of the lesson to me is that boilers contain awesome amounts of latent energy! Even little bitty ones! This hobby is meant to be fun so if you are going to work with steam. PLEASE OBEY THE RULES & be safe.
