- Dec 31, 2010
- 733
- 186
Even if I get plans from reputable sources I always re-draw them in my 3D modelling program. By the time I get finished modelling the engine I have a full understanding of how it goes together, and I almost always find errors or omissions in the drawings which I am able to correct. Back in 2015 I acquired the book by Vincent R. Gingery " Building the Atkinson Differential Engine" pictured below.
I had already built the "Atkinson Cycle Engine" also by Mr. Gingery with success. So I thought it would be a good addition.
Right from the beginning I was not impressed with the book. It starts off with how to make patterns to make your own casting and the dimensions required there and follows on with machining the castings. There are several places in the book where dimensions are confusing to say the least. To top it all off in the assembly instructions it states that you need to fiddle a bit to make it all work and even suggests that some parts might have to be re-made in order to get the mechanism to operate properly. Following that it is suggested that a very long run-in period of turning the engine over with an electric motor might be required.
To me none of that should be necessary. In my opinion if the plans are worth anything and you build it according to the plans the engine should be capable of running with not much more than typical fuel and ignition adjustments.
One of the advantages of a 3D model is that if the parts are constrained properly you can actually manually animate the engine by say turning the flywheel which will make all the other pieces move. Being that this engine has a very strange mechanism it was interesting to "operate" the model and see how it achieves the typical 4 cycles. You can turn the flywheel a few degrees and take measurements and figure things like compression etc.
What I noticed right off is that the engine was going to have VERY low compression. I figured about 2:1. I checked my drawings with what was in the book (factoring in the confusing drawings) but I still could not realize better compression.
I concluded that something had to be wrong with the drawings so I put it on hold and decided I'd ask one or two builders of the engine I'd seen running at shows what they had found to be wrong and what they did to fix it. I asked one fellow and he just said simply that he had to change something but he couldn't remember what. I contacted another fellow that had one running on YouTube. He said he made a wooden model first before he built it but had no details on what might have been altered.
SO I decided I wasn't going to build it and the files have been sitting on my computer for 5 years.
Then about a year ago on this forum I saw a post by Gordon entitled "Atkinson Frustrations'
https://www.homemodelenginemachinist.com/threads/atkinson-frustrations.30272/
Gordon had built the engine and was asking for help to make it run. One of his many comments was that the engine had poor compression. There was also another contributor (Ramoye) who was having the same problems.
So it appeared my drawings might have been correct. It was agreed that the plans were sketchy at best and unfortunately both of the Gentlemen had been through making a lot of new parts with limited success.
I decided that maybe I should analyze the model more closely to see what changes could be made to the mechanism to correct at least the compression issue.
This was no easy feat because almost any change of only a few thou in positioning of parts can make a HUGE difference in the operation in the differential motion of the two opposed pistons. I went through a couple of weeks of change something / observe the motion / see if it looks reasonable / make measurements to see if compression improved and mostly to see if there were collisions of parts and if the engine was still able to be built.
In the end I think I've (more or less stumbled) come up with a configuration that MIGHT work. Unfortunately a lot of the changes are not suited to being made to an existing engine built from the original plans. Too many parts would have to be re-made.
BUT I can certainly build a new engine from my plans to see what happens.
***** WARNING - This project may be a complete failure - but I think I can trust my drawings to build it. Although my analysis of the operation of 3D model may end in disaster when it tries to run. *****
SO follow along on what might turn out to be yet another unsuccessful Atkinson Differential Engine build.
I'll get started in a couple of days.
