Another small step ....
tel
.... for Telkind. Made myself a set of MT2 collet blocks. The square one had to be hogged out of a bit of 30mm round bar, hence the abbreviated corners, but they work well.
Simple and effective Tel, way to go :bow:
Regards cobber, Ian.
Good job. If flatten those corners a bit, you'll have a dandy octagonal holder...
Good job and I second the recommendation.
Tim
Hey I like that.. MT2 EH?.... Ocasionally I could use a square collet block in 5C..I am not in the right mood to make one because 5-c gadgets is so common and cheap..I'll go Enco.
Yeah Steve, that's the sensible way to do it, but since I have no 5C stuff and I do have a set of MT2 .......
Hi Tel,please excuse my Dutch Kiwi ignorance,but what do you use these blocks for?
I've never seen them.
Regards.Hans
I'm going to make a newbie guess:
The collet goes into one of the blocks and is tightened down on the workpiece (or tool) with the screw. Then the hex one can be gripped by a 3-jaw chuck and the square one with a 4-jaw.
While that is certainly possible, the more common use is in the mill to index cuts on a cylindrical part. Imagine cutting a square or hex tenon on the end of a cylinder.
Just to add to Marv's description, by using the correct block in your milling chuck, you can very easily machine the bar with either 1, 2, 3, 4, or 6 faces, without having to break out the spin indexer or RT, so losing your vice setup.
IMHO, if you have the collets, you should definitely have a pair of these in your collection.
This is just an example of a commercial unit for 5c collets.
http://www.fastenal.com/web/products/detail.ex?sku=0344213
Had a play this morning - made a special, short M8 plug tap. Here's the square on in use.
Hi
Ok I got it so far but how do you make the 2MT hole in the block?
Rich
I set the topslide over to the MT2 angle with a DTI, bored 'em and then finished with an MT2 reamer
