A viedo of my R.H. #3 under steam (Air)
Nice Job, slow and smooth
IronHorse
That is about the nicest variant of Rays #3 that I have seen.
What did you change? It looks to be about 2X size.
very nice work, beautiful finish and display.
A great job on Ray's #3 mill engine, one of my favorites. Nice video showing all the details. I'd like some info on the flywheel - was that cut from a piece of barstock?
Phil
Hello again
In reply to questions from Phil and kvom the flywheel is made up of three different pieces, the hub is 12L14 the spoke section the same and the rim is durabar which is a high grade of cast Iron (corect me here I don't know much about it) . The question now is why all the work, to tight to buy a big chunck of 12L14. The for mentioned stuff was scrounged, I like free! If you look on this same page I have Pic that will explane things better.
As the base goes (scrounged again) it;s made of Corian which is used makeing counter tops and the like. this is the first time I worked with it, it machines,taps and polishs very nice. Use a vacuum system when working with it!!! Was happy that it looked so much like concrete, seemed fitting for a base for a mill engine. The brick pattern was a PITA after I was to far into it I wish I never started, but it came out ok. Took over 12 hrs,only worked a bit at a time. Thanks for looking fellows and the kind remarks
Tom
Beautiful runner, I love engines that run slowly.
You describe it as R.H. #3 , but I havent a clue what R.H stands for .
Can you enlighten me and also can you tell me where I might get hold of a copy of the plans
so I can try to make one too
Don
Beautiful Tom!!! A perfectly smooth runner from what I can see and all your attention to detail and finish certainly shows up as well. Very well done indeed!!!!
Bill
tom nice job and good looking workmanship. nice job on the finish, and slow running. jonesie
Tom,
That is a beautiful looking engine. I'd say the time spent doing the bricks was well worth it.
Very Nice! The details like the conrod and exhaust stack are sweet! I really like the guard rail to. Nicely done! :bow:
In reply to Rons question on size of engine everything is as per the prints execpt the flywheel which called for width of rim to be 1.375 and I changed it to 1.250. Thought it look more to pourportion for the engine.
She's a beaut all right! What material did you use for the cylinder?
In regards to the question Cole had as to what the cly is made of just a block of 12L14, a nice free turning material. In fact the whole engine is built of the same,except the cly packing nut and the railing which is made of 303 stainless steel. The plans called for a brass packing nut, but its in a place that would be hard to polish so that's the reason for that. The rail the same it will not need much maintenance to keep it looking nice. Thanks for looking and the great comments.
Tom
Tom,
A beautiful model and well made it must be, to run so smoothly at low rpm. :bow: :bow:
Best Regards
