C
chiliviking
Guest
I have received my plans for the walking beam engine and have had a couple days to study them and I dont quite know what to think. It appears that the plans were drawn on CAD and some of the dimensions seem to be just what the program selected rather than a determination using sound engineering and practical sense.
I could cite many examples but will only list a couple to give an idea of what I am talking about. The profile on the outside of the main beam is described as a 14.783 degree cut. Like 15 degrees would be way too much and 14 would not be enough? The radius for a notch on the cylinder cover to clear the valve rod is described as a .100 radius. Knowing that most guys in a home shop environment will be cutting this with an end mill then wouldnt .093 so you could use a 3/16 mill or .109 for a 7/32 be more practical? I realize that these corrections can be made as you proceed with the project but I am left with the feeling that before any part is made one better study very carefully how this part interacts with the others before making any cuts. To some degree this is a required M.O. to proceed on any project but I have completed many projects where you could build each part to print and everything would assemble as it should. This may seem like knitpicking but the point Im trying to make is I dont think I could trust any of the dimensions without some serious checking which will complicate and lengthen the process.
I also have some concerns about the clearances on some parts and the choice of material on a few of the parts. I would really like to get some feedback from others that have had the opportunity to study the plans or better yet if someone has completed the project.
On a positive note it is a real nice design and I think would be a beautiful project when completed.
