Everything if seen and read about cutting a collet taper says that you need to insert a piece of stock that just fits the collet i.e. If it's a 1" collet you use a 1" piece of stock to keep the collet expanded to its full size. You are suggesting the exact opposite.I just want to point out that when checking the taper with a collet, the collet will be sprung open, making it a slightly different taper.
If you have a solid 5C shank it would be ideal to use for checking the taper.
Paul.
I have the steel to do that. Probably thread it and use permanent locktite right?Bummer, any chance of putting in some type of insert?
Paul.
