- Dec 12, 2012
- 2,220
- 1,275
Looking for my next project,needs to be sustantial.I now have more tooling than i have ever had and there is not much more to make so need to start using it.I have decided to start on the 5"simplex loco even if it never gets finished.The main reasons are i have the drawings,castings etc are readily available and its much simpler than the HEILAN LASSIE i got 75% complete
The last loco was in the early 2000s,i had 2 Myford lathes,vertical slide and drill
press etc.So there was lots of sawing and filing.I was also working long hours
Now i have a mill,lathes etc,and DRO on the mill for accurate drilling/boring etc And a lot more time on my hands
Downside is that bright bar in flats and angles and imperial is not readily available so much of it will have to be metric HRS,Will be working a mix of metric/imperial to suit.Where possible i will use hs cap screws,hex hds will have
to be purchased in BA . Will chart progress and compare the 2 builds from 2000
in UK to 2017 in Oz,Will start with the frames,stretchers and buffer beams so
can build up something to look at.Any advice where to get castings and fixings etc here in Oz
