Little more progress today.
I wanted the top and bottom bolt patterns to be close in alignment. Don't need to be exact but close is good. Made a small mark in sharpie on the jaw of the vise and then marked up the piece with a square off the top of the vise jaw.
Located the center of the hole and drilled in the pattern that will hold the top insulator to the base.
Rotated the part 180 degrees and aligned my mark with the mark on the vise jaw. Then I located the center of the bore. Only needed one hole to screw the electrode into but my lathe is so small I had to make 4 to bolt on a mandrel.
A mandrel was made from a scrap piece of ally to allow the piece to be mounted into the 9X20 lathe.
Now you can see why the 6 inch round was knocked down to 5.25 inches. I think there was about .050 or less between the piece and the cross slide.
Sorry about the picture quality but the camera battery died so the phone was used. The top portion of the piece was machined to size and shape.
The CNC machine doesn't seem to care about how the swarf is coming off, how much and where it ends up. I used a pair of needle nose pliers to coax the never ending stream of swarf to go onto the floor instead of wrapping around the chuck and everything else. After making tiny parts I was not prepared for the never ending stream of aluminum but we got through it with a nice looking piece.
