3 Cylinder 40% Scale Anzini W engine.
johanneskees
I built this engine from scratch. No castings. Problem with pistons, the aluminium expands to much. If I increase play the pistons become to loose. I used 6068 aluminium, what should I use. The bore is 40.5mm and the sleeves are centrifugally casted cast Iron.
Make cast iron piston rings, the spring in the rings will take up any expansion.
I would think two rings about 2.5mm wide and 1-1.5mm thick should do
J
I will post a couple of photographs. Just want to do the photographing. give ne 5 days please.
Thanks for the advice regarding cast Iron rings and 7075 alli.
hi ,
i build a engine with the sleeve en piston from a Citroën 1.1i, TU1JP (HFX)
to solve the problem above ( i'm just in an early stage of building without drawings );D
Here are the photos I promised. The engine is 199 cc. and the test propeller is 30 inches.
Measure and know!
Incredible work! :eek: I really like your engine! where you get the plans??
Thank you for the compliment, I took data from all over the internet and compiled my cwn drawings. Modified design slightly in order to make it practical for modelling without castings.
Really Top stuff mate
please Tell me your going to publish the Plan set :eek:
Pete
