Hi all,
This is a compound steam engine I started a while ago.
Few specs before the pictures;
Hp cylinder bore : 1.75"
Lp cylinder bore : 3.5"
Stroke : 3"
Designed for 500 rpm.
No casting, steel and bronze construction.
Needle or roller bearing where possible, assembled crank.
Valve design from Ray H. #10 (single cylinder column engine), rest of it is home designed.
Machinery used are an Atlas 10" lathe and a Deckel FP1 milling.
Most pictures were taken after some more assembly could be done, not much "how to" picture.
(thanks to people who does it, I simply never think of it while machining)
The build is going good, tonight it moved under air pressure for the very first time (quick check after valve timming)
Here it is !
Stroke : 3"
Here it is !
