K
Kermit
Guest
After thinking about locktite and small set screws, I finally adapted some washers to stop the bearing races from spreading apart when reversing direction with the lead screw. I have less than .010" worth of slop in the screw now. I wish it was zero, but I didn't pay enough to reach that number. This was a free fix.
I placed a thick washer on the spindle first to take up all the room at the head of the threads, I had to search for quite a while to find the second washer. It's a very thin stainless steel, and I got lucky that some simple touch up with a round file was all it needed to be a sliding fit on the shaft. The whole mess was then compressed in a vise and the gib key was pressed back in the shaft to keep it tight.
/what have others here done to correct the spreading of the bearings on these shafts?
Kermit
