dparker
In Rembrance 8/2021
- Aug 24, 2007
- 218
- 5
Hello All: I have a question about supplying the voltage to run my IC engines. As noted on my video of the 6 cycle engine in Photos and Video section, my 6 volt lantern battery was dead and I used my battery charger (on the 6 volt scale) to run the engine. It seemed to run well but will this damage my battery charger? The amperage would spike on the charger analog readout but never did register full scale so I let it run for the video.
The engines I have made use Mopar ignition points and condenser with a 1936 IHC truck coil for ignition components.
For running the engine at home this would save the problem of buying a battery and having it go dead before I used it again. If I were to take the engine somewhere and wanted to show it I would just go ahead and buy a battery.
So, my question is, am I safe using a battery charger to supply the voltage (and amperage) to run model IC engines?
I am interested in reading any answers that may be posted. Thank You.
don
don
