V-Block Fixture
Brian Rupnow
Design Engineer
Barrie, Ontario, Canada
Every once in a (rare) while, I have to stand a round part on end in my mill and do "something" to the end of it.---And up untill today, I didn't have any real good way of holding onto a round part standing on end. I am still waiting for some "real work" to come into my engineering office, so today I decided to make a V-block that would fit into my Tilt-A-Whirl vice. I hate to admit it, but it took me the entire day to make this, and fortunately I had a peice of 2" thick scrap aluminum plate around. I designed the 3 V's to accomodate any diameter rod from 1/8" up to 1 1/4" diameter. I stuck a peice of 5/16" round brass in the fixture, just for "show and tell". The fixture is a "good fit" over the fixed jaw in my vice, and can be lifted off without having to tighten or loosen the bolts holding the rear clamp bars in place.
This is an amazing act of Deja Vu.... was laying in bed this morning thinking that I had better make a start on my new screwless vice. I intend to cast the base etc etc etc..... my main thought this morning was that I will make the jaws both replaceable and sacrificial if need be but one set will have a set of V's in it to hold round stock on end..... then Brian posts........ spooky...... I think I may have to go back to bed to recover.......
Personally Brian I see this as an act of Genius.... (naturally).....
I stood the part in my vice at 45 degrees and milled the notches with a 1" diameter end mill. I laid out lines on the piece of aluminum and milled to the lines.
This is a good work holding block. I've used a couple like it for years now, and it saves a lot of fiddling around. When I made mine, I put only one "V" groove in each one, on center to keep the moveable jaw of the vise from trying to cock sideways.
Dean
Dean
To solve this, you can drill and tap a hole on each side of the fixture, insert a little adjuster screw on the opposite side of the work to hold the jaw.
Looks good as always, I made one that just sits in the vise, (no notched back)
-B-
p.s. what happened to the chip guard at the back of the mill
