Hi All
Back in the workshop after completing the McOnie and after much musing decided on this launch engine , fabricating everything.
I found some nice rendered drawings on line and there is enough detail to work from.
Started with a lump of bronze and slowly whittled away the bits I didn't want. The valve chests are just silver soldered from
brass sections. the base is taking shape from brass plate.
The four drain cocks took the longest to make as they are fairly fiddly.
I will endeavour to update as soon as possible.
Regards Mike.
Regards Mike.
