- Aug 22, 2007
- 193
- 1
I was threading a short piece of steel for a new tool I am making and I had made 3 passes and all was well until I started the 4th pass. It started cutting the "hill" instead of the "valley" of the thread. Once I realized what was happening I stopped the process because I knew the tool was gone.
I have a EMCO V10 and once I engaged the half nut I did not disengage it.
I would back out the cross slide and reverse the drive to get it back to the start. Is this a no-no to reverse it to get back to the start or should I be using the threading wheel???? If so why did the first 3 passes work??? I have threaded before using this method and it worked OK. I'm stumped as to what may have happened.
Julian G. :?:
Julian G. :?:
