Suitable Grease for lathe bearings?
Mark-One
Active Member
G'day all
First post, so be gentle ;)
The other day my uncle brought over a Unimat DB200 for me to try out. I've no previous lathe experience, and everything I know currently is contained in whatever manuals he had.
This machine has probably not seen use for some years.
Since I broke one of the dry old rubber belts in short order, I feel I should give this thing its 1000 hour service, as specified in the manual, which involves repacking the headstock bearings, amoung other things, while I wait for replacement belts.
My question for you folks is what is the preferred sort of grease to be using for such things these days? I've got a tub of plain old axle/wheel bearing grease in the garage, but I'm not sure if what is good for automotive use is also suitable for a little machine like this.
I did a quick search, but did not find another post on this topic.
I would find it hard to believe that the bearings in a small lathe take more abuse than those in the front wheels of a vehicle. If it's good enough for your car (ATV, trailer, whatever), it ought to be good enough for this as well.
G'day Mark
Unimat Oz has a slip that recommends unimoll grease
its a shell product that is used in motorcycle bearings, trailer wheel bearings, etc
but has the same ID number as "general light bearing grease" here
this is very old info ( late 70's) dunno what its equivalent is today
hope this helps
cheers
jack
A lithium based No. 2 Grease - Such as Shell Alvania EP2.
If we are talking about ball/roller bearings the repacking grease should fill about 1/3 of the space available in the bearing.
Best Regards
Thanks all.
My main concern with the automotive grease was that it might be too heavy for a smaller machine in the same way that I wouldn't use it to lube a ball bearing computer fan.
I just wasn't sure if it mattered.
Thanks for the links and info. I'll check out that yahoo group.
I found the answer in the form of a helpful ebay merchant who sells Unimat parts.
He's also helping me to troubleshoot my motor, which suffered a sudden death yesterday :(
Anyway, a #1 grease is the one to use, as #2 is too heavy and will lead to excessive heat buildup. I had no idea what #1 grease was until I went looking around a few auto stores and talking to people who knew less than I did (no one had ever heard of a #1 grease).
There's an NLGI rating on the tubs. I found 2, 1.5 and 1. Opening them up and having a look I could see that the grade 1 stuff was less stiff than a grade 2, so I made a logical leap and bought some grade 1 moly based stuff.
There's a wiki here explaining the grades of grease and their relative viscosity, if anyone is interested.
http://en.wikipedia.org/wiki/NLGI_Grade
Now if I can fix this dead motor, I'll be back in business :/
For the belts, DO NOT spend big bucks on some of the stuff from e-bay, because all they are is " O " rings. Yep, these sellers buy the O rings by the box full, for cents each and then flog each of them for lots of dollars.
Go take the busted O ring belt to someone who sells O rings and you to can have plenty of them CHEAP.
You will here about another belt that can be joined with heat, OK, it's a lot dearer than the O rings as well.
A word of warning with ANY belt you may have fitted to ANY little Unimat, be it a DB/SL or U 3, DO NOT leave the belts on overnight, or, for a fortnight, they do stretch and then they crack and they are stuffed, just take them off after each use and they will last for a year or more.
regards greenie
Mark,
SKF Bearing grease recommendations:
Bearings with O/D < 62mm = lithium soap grease with NGLI 2 consistency (MT 47) and a temperature range of -30 to +110 deg. C.
Bearings with O/D > 62mm = lithium based grease with NGLI 3 consistency (MT 33) and a temperature range of -30 to +120 deg. C.
Hope this helps ???
Best Regards
