Bob Sorenson
Active Member
Today is a short update to finish the connecting rod. Round over the end of the con rod on the rotary table. Center the rotary table directly under the mill spindle. Clamp down a slab of aluminum and drill for a 3/8” pin. Secure the connecting rod on the pin and round over the end.
The rotary table is the way to go. The finish is almost glass.
To mill the slot for the cross head, make a slot in an aluminum plate to snugly fit the con rod.
Clamp the connecting rod in the slot and mill for the crosshead.
The plan calls for a fully rounded bottom end of the slot. Future me will discover that a fully rounded bottom end will foul the crosshead. It would be better to finish the crosshead slot with a ¼” diameter end mill.
That’s it for the connecting rod. Next time is the crosshead and piston rod.
At the time of this writing the engine is done and only 3 or 4 little parts remain on the Stevenson reverse mechanism. Hopefully get this monster running on air in a couple weeks. I’m getting nervous.
Take care Bob
Take care Bob
