I have a set of plans for a stirling engine that calls out aluminum for the hot and cold displacer cylinders. Could I use stainless steel instead. The only reason I want to substitute the material is because I have some extra stainless laying around but, no aluminum that size. I am sure SS is not ideal because of the hardness as far as machining goes but, if it will work I would like to use the material I have. Thank you in advance for your advice.
Dan
Dan
