I don't have the plans anymore, I think he has them but they can be found all around the INTERNET, variations of the same thing. Basically you take a tran. of the right size (check the plans, and it depends on what you want it weld) strip off the the outer coil, Rap heavy welding cable around the inner core as tight as possible, any gap reduces output, and thats basically a spot welder. Now for the extras, current control and a timer to control the spot weld time (again check the plans), handy for not melting the wiring in your shop and necessary housing and mechanical accessories to make it work.
And the most important thing, Please don't electrocute yourself.
I will try and locate something on this subject and let you know.
P.S. Kludge if you have anymore info on that capacitance discharge welder could you post it, looks like a interesting piece of equipment to make.
