Solid Edge 2D issue
Help Support HMEM:
Dmurphree
Wondering if anyone else uses SE2d. I have done something that has caused the software to stop displaying the dimensions on the drawing.:confused: I can measure between two lines and go through the process of adding the dimension but all it displays is the dimension line. No big deal because I uninstall and re install and go back to the default but I would prefer not to do that.:mad: Has anyone seen this problem or have an idea how to fix it?:wall:
Murf
nodaker
Hello,
I have solid edge 2d and have played with it a bit. I am more versed in AutoCAD than solid edge. If SE 2d has a properties window open it, select a dimension and use it to check the scale of the text and arrowheads. If set too small, it will appear as though there is no text or arrowheads in ACAD.
I tried opening SE on my machine and the license file has expired. I will update my system and check out the dimension issue on it.
Please reply to continue this discussion.
Group Builder
