Real simple tool holder...
Having come to the conclusion that HSS will be the turning tool of choice from now on I needed to get some tool holders, so, nothing to do but make a couple of them...
Started with a bit of steel, nothing special just mild steel rectangular....
IMGP9402 by
aardvark_akubra, on Flickr
The mill vice was set to about 6 degrees...
IMGP9404 by
Now I thought this was a good idea, two very strong magnets holding the workpiece flush with the top of the vice jaws...
IMGP9403 by
.............well, it seemed to be a good idea at the time.
I started milling a slot using a two flute milling tool and a dribble of cutting fluid....
IMGP9405 by
..............you can see the problem already, the chips are magnetic and dont want to be brushed aside! Oh dear!
Slot cut and a bit of a tidy up of the metal..
IMGP9409 by
..... the tool is a slide fit in the slot.
A bit of precision work with the aptly named hack saw...
IMGP9410 by
Some cold blue makes it look somewhat presentable...
IMGP9413 by
And it works a treat.....
IMGP9412 by
..... the tool post clamp puts enough pressure on to close the saw cut a little and grip the tool.
I am so pleased I think I will make another one..
