Hi Guys,
I recently acquired a second-hand 6" rotary table complete with dividing plates. Problem is that the plates are small. They are about 75nn dia instead of the usual 100mm and the fixing holes are in an unusual position. They are at about ten to two viewed from the front. The plates were already attached and were missing the brass fingers but I should be able to make some of them. The standard rotary table turning knob was not present so again I may have to make one. The table turns in ratio 40:1. The circle in the centre taps out to give a large centre hole but with no taper.
If I know the make I should be able to buy spares and more div plates but no markings whatsoever. Anyone got any ideas or suggestions?
julian
julian
