Roger's work shop
mecanotrain
Active Member
Hello Great Modelers,
Here are some pics of my home work shop:
The lathe EMCO Compact8 (450mm x 105mm)
The drill/mill SYDERIC PF32 (350mm x 200mm)
Guillotine shears (700mm x 1mm)
Brake bender and slip roll (300mm x 1mm)
Slow speed saw for steel
Home made high speed saw for brass, dural, wood, plastic, ….
Tools grinding machine
Home made 20 ton hydraulic press
Sand blast cabinet with air compressor
Home made cutting off machine (only bar brass)
And oxy/acet torch, propane torch, arc welder, spot welder, home made saw welder, foundry furnace, …
Nice set-up. You have a lot more capabilities than I do.
Mecanotrain,
Very nice collection of tools you have. I have not seen a grinder like your tool grinder before. It looks like it can be adjusted to do lots of different work besides tool grinding. I would like to know more about it.
Thank you for posting your shop pictures.
--ShopShoe
Great setup Roger, top marks Thm:
your inverted bottle jack on your press intrigues, me never seen that done before ??? care to share the secret on how to do that ;D
Terry
I like the saw, too! Something like that is super-handy for pieces a bit too large for a hack saw, and the cut is probably super-straight. You could mount a drip lube setup on there for ferrous or aluminum, if you wanted.
Thanks for sharing.
Nice, some clever approaches to home made tooling too.
Smifffy
My name is Roger, too. Does that mean I get to use the shop?
Terry
Hello Terry, All,
Sorry for the delay ! I've several hobbies: here is another, but that's another story ...
oilerman for a big live steam locomotive
the locomotive MIKADO 141 R1126 (oops 282 for you) GREAT US locomotive
Jack works for the reverse, it is necessary that the pump is immersed in oil. It's easy !!
Here's a little drawing to explain:
Hi Roger. Thanks for posting some great machinery. I can't get over the size of the wheels on the locomotive. Must be close to six feet diameter. 8) :eek:
Hi Roger,
Nice to see you on this forum. That locomotive looks like a fun hobby.
Dan
Hi Roger,
Thanks for the details on the bottle jack, so simple, I was over thinking it :D
Great to see you have some outdoor activities, keeps us balanced ;D
Terry
Hi Herbie, All
The size is 165cm = 5.41 feet. The builder is ALCo (1946)
Hi Roger.
Very nice, well equipped workshop you have. :bow:
Thats a mighty fine loco you help out with there Roger ::)
This is what passes my back garden many times a day, Its the other end of the spectrum (Not to mention the other side of the world) to your Mikado
http://www.rhdr.org.uk/
Ray
