Questing about a flywheel casting issue.
Discussion in 'Engines From Castings' started by Clarksville Don, Sep 26, 2019.
  1. Sep 26, 2019 #1
    Clarksville Don
    Clarksville Don
    Clarksville Don
    Jun 4, 2018
    8
    4
    Gender:
    Male
    Occupation:
    Retired industrial service tech
    Southwest Ohio
    IMG_1275.JPG I am working on a Red Wing water cooled kit from PM Research. I had an issue getting a drill to run true when drilling the flywheel hub prior to boring and reaming. On the second flywheel I noticed a strange pattern on the face of the hub after I took a facing cut. There is a light colored disk about 70% of the diameter of the hub that is offset from the center of the hub. there are 6 small diameter dark spots inside of the light area. If these spots are of a different hardness it could explain the issue with drilling. I asked PM Research and they stated it was from part of the casting process but did not provide any explanation of the process that gives this issue. Does anyone have any info?
  2. Sep 26, 2019 #2
    johnmcc69
    johnmcc69
    johnmcc69
    Dec 5, 2011
    267
    39
    Weird. I wonder if originally they had a core there & was out of location (obviously), removed the core on the cast flywheel & "filled" the cored hole in afterwards...
    Dunno....
  3. Sep 28, 2019 #3
    Jack3M
    Jack3M
    Jack3M
    Jul 11, 2017
    286
    139
    Bizarre, if it were not for that perfect offset circle I would have said hard spots from chilling.
    Coming back to your drill bit wandering, I find that using cobalt bits will resolve that unless there are very unequal hard spots.
  4. Sep 28, 2019 #4
    WOB
    WOB
    WOB
    Sep 12, 2013
    185
    33
    If it is some sort of chilled iron from making the casting, it will likely be impossible to machine it with HSS tools. A plunge cut with a carbide end mill will make the initial hole and then a carbide boring bar will allow you to size the hole accurately. Reaming should not be necessary.
    WOB
  5. Sep 28, 2019 #5
    Clarksville Don
    Clarksville Don
    Clarksville Don
    Jun 4, 2018
    8
    4
    Gender:
    Male
    Occupation:
    Southwest Ohio
    WOB
    Thanks fo your input. I do have a small carbide tipped boring bar and used it to finish the bore of the first flywheel. Your suggestion of starting with a carbide end mill sounds good. Thanks
    Don
  6. Sep 29, 2019 #6
    larryg
    larryg
    larryg
    Mar 24, 2015
    59
    28
    Gender:
    Male
    Occupation:
    Retired Maintenance tech now Farmer
    Oregon, USA
    I think I'd be inclined to reverse the flywheel in the chuck and face the other side to see if the 'plug' goes all the way through. It does look way to round to be a casting flaw.
    lg
    no neat sig line
  7. Sep 30, 2019 #7
    Philipintexas
    Philipintexas
    Philipintexas
    Apr 13, 2012
    224
    52
    Do the “circles” correspond to, or align with the spokes? Could they be some kind of harmonic caused by them????
    I built that same engine and all my castings were of the highest order.
    Either that or they are caused by the same thing that creates “Crop Circles”! Really strange.
  8. Oct 1, 2019 #8
    Jack3M
    Jack3M
    Jack3M
    Jul 11, 2017
    286
    139
    Interesting point. Once I screwed up a flywheel so I made a plug for it that was a press fit. This reminds me of that.
    I will be most interested to hear how the hole process went and if that also shows on the other side if faced. Very curious one here indeed.
  9. Oct 1, 2019 #9
    TonyM
    TonyM
    TonyM
    Well-Known Member Project of the Month Winner
    May 15, 2017
    254
    146
    Gender:
    Male
    Occupation:
    Retired
    North Bohemia Czech Republic
    Did you flip it round and skim the opposite side to see if its the same
  10. Oct 1, 2019 #10
    jlchapman
    jlchapman
    jlchapman
    Active Member HMEM Supporter
    Dec 18, 2018
    34
    5
    Gender:
    Male
    UT
    I had the same question earlier this year. So this was the response from PM Research:
    That is how the casting is made. The center core is placed in there to keep the flywheel from collapsing at the foundry. That is a good flywheel.
    Jerry
  11. Oct 1, 2019 #11
    Clarksville Don
    Clarksville Don
    Clarksville Don
    Jun 4, 2018
    8
    4
    Gender:
    Male
    Occupation:
    Southwest Ohio
    IMG_1285.JPG IMG_1284.JPG Thanks for all the input. I did flip the flywheel and do a face cut and the pattern does go through. It does not have the 6 small dots on the second side (first photo). I also faced the first side to final size by taking another .o25 facing cut. The pattern looked like it was starting to go away?( second photo). I did manage to get a 5/16 drill through the hub with a small amount of wobble. I trued the hole by using a 3/8 end mill and will now be able to bore to final size.
    Don
  12. Oct 2, 2019 #12
    TonyM
    TonyM
    TonyM
    May 15, 2017
    254
    146
    Gender:
    Male
    Occupation:
    Retired
    That's interesting.
    I guess it is just a PM solution for a specific problematic mould although I would assume there is a big risk of hard spots around the join.
    It would be nice to know if the core showed up on the casting before machining as I can't quite see how it would be located in the mould unless it does.
  13. Oct 2, 2019 #13
    Clarksville Don
    Clarksville Don
    Clarksville Don
    Jun 4, 2018
    8
    4
    Gender:
    Male
    Occupation:
    Southwest Ohio
    The pattern could not be seen before the facing cut. From the way drills and the end mill reacted, there were hard spots in the casting.
    Don
  14. Oct 3, 2019 #14
    TonyM
    TonyM
    TonyM
    May 15, 2017
    254
    146
    Gender:
    Male
    Occupation:
    Retired
    OK so I am not familiar with casting processes. It would be great if someone anyone who is knowlegeable about casting could throw some light on how this 'included core' process might be done and why it doesn't show up externally on the casting?
  15. Oct 3, 2019 #15
    Philipintexas
    Philipintexas
    Philipintexas
    Apr 13, 2012
    224
    52
    Ditto to that! My understanding of a “core” is that they usually leave a recess in a part. IE: the water-jacket of a Corliss
  16. Oct 4, 2019 #16
    MachineTom
    MachineTom
    MachineTom
    Senior Member HMEM Supporter
    Oct 20, 2010
    897
    124
    Odd that they left a piece to hold the 2 mold halfs apart. As the flywheel is split, would not seem to be needed.
  17. Oct 4, 2019 #17
    Fogey
    Fogey
    Fogey
    New Member
    May 15, 2018
    2
    1
    Gender:
    Male
    Occupation:
    Retired
    Northern Michigan
    I had the same issue in my Redwing. When facing the hub there was no doubt something was in there. Harder than Hades! Changed to finish with carbide. Also spoke to PM at the NAMES show, they gave me the same answer about the core in the casting. It looks to me like they placed some odd metal in the mould as filler.
  18. Oct 5, 2019 #18
    tjwal
    tjwal
    tjwal
    Sep 22, 2013
    79
    7
    My guess is that it serves as a chill so the hub cools quicker. In general when casting it is best to have the parts of the mold furthest from the sprue to cool first.
Draft saved Draft deleted
Share This Page
