hi, i have a bolt we will call it, with a threaded end which measures 9.3mm width ( outside diameter of threads), i have bored out a hole between 8.5mm to 9mm, and tapped it but the bolt is to loose in the 9mm hole and to tight in the 8.5 mm, how do i work out what size hole to bore before tapping to accept the bolt(9.3mm) or how do i measure the depth of the actual thread ie in the valley of the thread, i hope this explains what im trying to say! ,thanks
