QCTP and accessories
ScottM
Active Member
Awhile back I asked for some opinions of what size QCTP to buy, and thanks again for the responses!
So I thought I'd share what I did.
I picked up the AXA size Phase II from Enco, A compound from E-Bay and a big chunk of 1018 bar to make a base for the compound.
http://i287.photobucket.com/albums/ll154/ScottMpics/DSCN0101.jpg
The cable ties are temporary to see if i like the location.
And some extra holders from CDCO, and replacement set screws from McMaster Carr(92905A316
Alloy Stl Extended (dog) Point Sckt Set Screw, M8 Size, 20mm Length, 1.25mm Pitch).
I pulled all the height adjustment screws degreased them and the hole, beveled the bottom of each so the would seat correctly
and locktited them in place.
Well so now I've got all these holders and no good way to store them so I built this.
http://i287.photobucket.com/albums/ll154/ScottMpics/DSCN0109.jpg?t=1237757353
http://i287.photobucket.com/albums/ll154/ScottMpics/DSCN0110.jpg?t=1237757439
All thoes little pices of steel too a while to clean up, the edges were all broken on the grinder then rounded out on a deburring wheel.
- Scott
