I'm considering building my first IC engine and was wondering what the difference would be (construction wise) between planning to power the engine with gas or propane. Overall, which method is better, etc?
Thank you,
Dan
Thank you,
Dan
dnp101677 said:I'm considering building my first IC engine and was wondering what the difference would be (construction wise) between planning to power the engine with gas or propane. Overall, which method is better, etc?
Thank you,
Dan
cfellows said:Lubrication becomes more critical if you are using propane. With gasoline engines, I usually just mix the oil in with the gas. With propane, you have to use separate oilers and make sure they work adequately.
I know that if you are making a hit n miss engine, you need a demand valve to stop the flow of propane between firings. However, I've read that you don't really need a demand valve if the engine fires all the time. Probably best for safety reasons to have a demand valve anyway, in case the engine stops running and nobody is around to shut off the propane.
As far as performance, I haven't really read anywhere that one is any better than the other. As Metal Butcher says, propane is cleaner than gasoline, but if you use coleman fuel instead, it's cleaner than gasoline also.
Chuck
Metal Butcher said:Hi Chuck. Thanks for your input. Colman fuel it-is for my first IC build. Its gonna get very cold up here real soon. Would the use of a Cast Iron cylinder need additional lube in the fuel or a drip oiler at the cylinder?
Dan. below is a link that might be helpful. It Looks like an on demand delivery valve is whats needed.
http://www.floridaame.org/HowTo2.htm
-MB
