Hi guys,
Years and years ago(10 maybe), I built myself a small furnace.
The only fuel I had available to me at that time was BBQ heat beads with a blower. This worked well but as many of you know it is messy when the ash vitrifies into a hard glass like substance. This was very difficult to remove from the furnace floor/walls and would damage the refractory.
I used it a couple of times for some simple aluminium castings, but due to the mess I tired of the heat beads and then it went into storage while I made a propane burner, which never got finished.
I am starting to build a Kerzel Hit&Miss engine and would like to cast the flywheels in brass/bronze.
I purchased a propane torch kit the other day(Primus/Sievert Tradeflame) for silver soldering needs for another project and noticed there was a large-ish burner available for the torch.
The burner has a diameter of 25mm(1") has gas consumption of 550g/Hr (~ 1.2lb/Hr) and a claimed power of 7 kilowatts, which according to an online calculator is equivalent to approx. 24,000 BTU's.
My question... how well will this burner work with my furnace, which is(from memory.. it is currently burried under crap in the shed) about 8" Internal diameter, approx, 12" high with an approx 2" exhaust hole in the lid. The floor,walls and lid are about 2.5" thick castable refractory (which was very expensive!)
While I'm reasonably confident I could do ali .... what are my chances with brass/bronze?
I would test it, but I'm still waiting for delivery of a couple of crucibles.
Simon
Simon
