Hi gents,
I have recently completed Elmers #24 Beam Engine (apart from some tarting up, rough edges etc and spray-painting, maybe a teenie bit of bling!) but I am having no joy in getting it to run.
It is doubled up in size and I know that I have made the parts to the correct dimensions.
When the piston is down, I connect the air and it will go to the top of the stroke but then stops. With the piston in the upper position there is slight movement but I can not turn it by hand as because of the air pressure in the piston. It is not binding on any other part as I can turn it using the flywheel axle by finger and thumb with the air off. I do not think it could be because of the flywheels weight (no brass that dia') though I could be wrong.
Trout, I see you have completed one in your three in one go project which has been brilliant to follow even if its in time-lapse Rof} :hDe:
I did not make this a pictorial build as I believe there have been others who have done so but saying that, perhaps I should of because any errors made, could of been pointed out to me.
Also, it would of kept Zee happy with the pics!! Thm:
I have included a few pics if this helps.
Kind regards all,
Ron.
Kind regards all,
Ron.
