Printed Circuit Board Drilling
Discussion in 'Machining with Disabilities' started by GailInNM, Dec 2, 2013.
  1. Dec 2, 2013 #1
    GailInNM
    GailInNM
    GailInNM
    Administrator Staff Member Administrator Global Moderator
    Feb 17, 2008
    2,204
    331
    Years ago I could accurately drill a PCB at a rate of about 20 holes per minute. With decreased vision due to age and other things I no longer have any depth perception and found I could only do about 1 hole every 2 minutes and about a third of them were off center. So time for a fixture of sorts to fit my Cameron high speed drill press.
    I started with a small closed circuit TV camera, about $9 dollars on ebay, and a 6 inch or so automotive backup TV monitor that I had on hand. The automotive monitor monitor works well as I could reverse the left/right and up/down directions to suit the camera orientation so the PCB moved in a natural direction on the screen.
    After a little bit of sketching I came up with something like this. The photos show the fixture with out the LED's as I found out that the ambient room light shining through the PCB gave better contrast with the translucent PCB. It's only a few minute job to install them if dealing with an opaque PCB.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I have other cross hairs made up with white instead of black and a double cross hair with black lines in the vertical direction and white lines rotated at 45 degrees.
    [​IMG]
    In operation. The cross hair is positioned over a hole just drilled and the next hole to be drilled is above it.
    [​IMG]
Draft saved Draft deleted
Share This Page
Group Builder
