Hi all,
I'm building a Poppin vacuum engine.
The flame inlet valve (hole) is in the centre of the head.
The barrel is air cooled aluminum with a thin bronze liner.
Looking at the thermal efficiency of the various metals I was wondering if it would be better to use ordinary low carbon steel for the head rather than aluminum or brass, as it would have much less heat transfer.
My reasoning is that the head is mainly to feed the flame and is exposed to the heat source continually so a poor thermal conductor should be better.
The cylinder will have the main cooling effect and if the head is a high heat conductor then the head will transfer heat from the flame throughout the full engine cycle, which you don't really want.
Steel on the other hand would not as it has poor thermal transfer ability.
The plans I am working from are for a totally cast iron engine, but I'm not going that way as I'm only using materials I have to hand.
The downside is that the steel will go rusty if not oiled over after use, but it would be more durable for wear from the flap valve.
What do you recon?
