Naiveambition
- May 15, 2012
- 367
- 93
I've been polishing on and off for a while now and thought I would throw some info to those in need. I usually start with 400 grit wet sand if the nicks aren't bad, this is also where most rouge will produce a good shine. But it can be better
After u have an even surface while sanding in one direction, or back and forth, don't just do random spins. After 400, go 600 and change direction of your sanding, once all of the opposite scratches are gone you can switch to the following grit. I usually go straight to 1200 from here, by now it should be producing a nice shine. The sanding is a little tiresome on the small parts, but this also will produce nice clean edges and less buffing time for rounded corners.
The rouge I use generally is the green stick rouge. Eastwood , and truck stops, have them. A liquid green one is also very good. It considered jewel ears rouge I believe. Use a Cotton buffing wheel on a good drill, load up the wheel. Don't be shy get it on there. Then start working your peice back and forth.try to move in even, parallel lines for bigger pieces. The wheel cuts more one way than the other , depending on your movement. The color stroke is the last ones where you feed in one direction only . Clockwise rotation with left to right feed. Hope that makes sense.
Use a fresh cotton wheel with different rouges. Never mix them
Finish off with white rouge. This is where it gets really nice. Same thing don't be afraid to load up the wheel. Once it reaches enough polish it will become rather easy to make it really shine.
This way is far superior to just using mothers style polishes. Most all steels and aluminum will look chromed.
