dan s
Active Member
- Jan 25, 2008
- 25
- 0
Im planning to make 2 new workbenches for my shop and before I started ordering material, I Wanted to run the design by everybody.
My design requirements are as follows:
1. Must be open underneath for role away tool storage.
2. Must be able to break it down for moving purposes
3. Must be able to handle a load of 1000 lbs (in case I get a bigger lathe ;D)
What I came up with is as follows:
Overall dimensions - W 72, D 30, H 40 44 (adjustable)
Top - 4 thick laminated hard maple. It should look pretty good when finished and provide good vibration dampening properties.
The legs & horizontal cross bracing are 2.5 x .12 square tubing
The rear diagonal bracing is 1-1/2 x 3/16 flat bar bolted to the legs. The theory is that since I have diagonals in both directions one is always under tension.
What does everyone think?
