Plans for Brass Stirling '60'
Help Support HMEM:
shred
Very nice. It takes a lot of extra work to draw up plans. Much appreciated.
kendo
Hi Jeroen Jonkman
Great looking engine,and a great build. Thanks for sharing
Best Regard
Ken
arnoldb
Hi Jeroen
:bow: Thank you VERY much indeed for the plans sir! - This is a definite build for me in future; especially as it uses materials I can get!
Kind regards, Arnold
kustomkb
Thank You Jeroen,
It is very nice.
Jeroen's video of the completed engine;
[ame]http://www.youtube.com/watch?v=HL-YWNYp7zA[/ame]
watchman
New Member
Hi Jeroen,
Thanks for sharing your plans - this is now my next project while I pluck up courage to start on a traction engine - again!
I have a question though - how did you make the displacer? Did you turn and bore it from solid, spin it, draw it or what?
many thanks, Ian
Hi Ian,
the displacer was turned from solid, with the inner radius made with a drill-bit shaped especially for the job.
The inner radius is not critical, I just wanted to take out as much of the weight I could. After the drilling/boring the workpiece is flipped in the chuck and the outer radius is turned. Be sure to fill the displacer with a piece of scrap material of the correct size to prevent damage caused by the jaws or collet.
Good luck and keep us informed of your progress!
Jeroen
xander18
New Member
Hello,
Thanks for the plans, these are excellent. I might build one for my grandfather.
Right now I'm just modelling the engine in Solidworks but I can't find the drawings for the two rods that connect to the crank. I'm sure I can find a way to model it but I was wondering if I am misreading your drawings.
Thanks,
Xander
mh121
Thanks for sharing jeroen, I now appreciate the time it takes to draw up the plans after spending months trying to do the ones for the pump I made. I will put this one on the to do list now I have my small lathe to play with. Excellent build.
MartinH
lazylathe
This has also been featured on:
http://www.machinistblog.com/
No affiliation or anything, just another site i look at for info and plans and tips!
Great work Jeroen and thanks for sharing!!!! Thm:
Andrew
atenenb
Hi Jeroen,
How did you bored grooves for the o rings?
I find it quite difficult to bore it in square shape.
Please advise.
wackyvorlon
Hi Jeroen,
Please advise.
Yeah, it'll want to ring like crazy. Try making a form tool with a rounded end instead of a square one. It will allow you to enter more gradually, reducing the risk of vibration. Make sure it's very well supported. Try reducing the speed and increasing feed.
Since it's an o-ring, a rounded bottom to the groove will be fine.
atenenb
I found that PDF that was posted by Jeroen is missing 2 rods.
One connects to tumbler plate on one end and to crank on another.
Second one connects to crank on one end and to displacer rod end on another.
Most important property of those rods are their length. Did anyone figured it out?
Hansi1959
New Member
Same problem here….
Still no one figure it out?
Thanks.
atenenb
Hi,
I created entire assembly including the rods in SolidWorks.
It does not allow me to upload it to the forum because of it's size (even zipped). Post your email, I will send it to you.
texta
Active Member
can anyone tell me why links like the first one in this thread never work for me , they always just take me to the front page never to the item in question . thanks .
johno
