Hello everyone;
I'm new to this hobby but have an engineering background - so pardon my stupidity!! I'm in the process (slow process) of building an Upshur horizontal twin using aluminum piston, Viton o-ring and steel cylinder sleeve. I've read a fair amount of info on how people finish the piston to bore surface; but there seems to be wide variation on how fine a surface is created ON THE PISTON. Some simply finish off with fine sandpaper to the final diameter, others go to the trouble of honing. I'm assuming that for a cast iron ring you'd want a fine, honed surface mainly to maintain compression whereas with a Viton o-ring a "less smooth finish" to collect some oil for lubrication is better. At any rate "how smooth" a finish do people work to in practice. The question is not just specific to the Upshur, as I plan to build other cast iron piston ringed engines later as well. Any and all guidance would be appreciated.
Thanks and best regards
Garry
Garry
