Optimum angle for turbine blades
Ripcrow
Trying to build a jet turbine. So far attempt one fired but failed to drive turbine. Attempting lighter weight turbine but just wondering what are the best angles for exhaust and compressor blades
there's a bit more to it than that. compressor and turbine wheels tend to be matched together using lots of weird and wonderful formulas.
do you have any info about your turbine your trying to make...... sizes etc.
Ripcrow
Have you come across the GTBA. Gas Turbine Builders Association.
Lots of useful info on building your own turbine.
Thanks
Sean
Ill check them out thanks. Just found that I had to modify my flame tube done that now shaft and tube collide. At least I'm getting plenty of practice
