A question in two parts, the first part WHY, and the second
part HOW?
I read an article in MEW (Model Engineers Workshop) titled
An Introduction to Milling.
In relation to setting up the milling vice, the author wrote
Use the correct size tee slot nuts and bolts for your machine.
Use a heavy flat washer of at least 5mm thick as a minimum
under the clamping nut and do not over tighten the nut.
In another article in a different issue by a different author, also
regarding fixing things to the mill table, The shortest studs
in my set are too long for some vices and fixtures so I often
use M12x30mm Allen head HT bolts with a home made
10mm thick x 20 or 30mm washer to increase the head
size. These washers help to bridge the oversize slots in
some fixtures aimed at the Bridgeport market.
My first question, the WHY concerns what determines
the thickness of the washer?
Does the washer simply have to be thick enough not
to distort/bow under the clamping pressure?
Are two 2mm washers stacked on each other the same
as one 4mm washer?
Now the HOW?
What are some of the methods of making thick washers?
I seem to remember reading somewhere that one method is
to turn the outside diameter required and then use a parting
tool to cut grooves at intervals for the required number of
washers. These grooves would go to a depth so that when
you drilled the centre hole from the tailstock, the drill would
break through the grooves and the washers would end up
sitting on the drill.
I guess the faces of the washers would have to be cleaned
up somehow!
How would some of you do it??
part HOW?
as one 4mm washer?
Now the HOW?
up somehow!
