I'm an aging woodworker who's looking for a new hobby that will let me sit and take the weight off my knees. Model machining looks attractive, but I've not yet invested in a lathe.
I found an interesting plan for a "Model Marine Engine Requires no Casting" at:
http://www.john-tom.com/MyPlans/Steam Engines/MarineEngine.pdf
Unfortunately, the drawings are not complete. The block shows exhaust ports drilled directly into the cylinder, but there is no end view to show where those ports are located vertically. That would seem an easy solution in a single-acting engine, where the exhaust would be at the end of the stroke, but this engine is double acting. So the only location that could work would be half way up the bore.
That would seem to halve the effective stroke -- won't that throw out half of the engine's power?
The piston valve controls the steam inlets, but nothing seems to control the exhaust. Angling the inlet ports towards the center of the valve would seem to allow more room that might allow the valve to control the exhaust also. How could I modify the valve piston to handle the exhaust?
I looked for a plan for another double acting engine with a piston valve that might show how that's done, but I didn't find one. Would any of you know of a plan? Could you recommend an introductory book that explains it?
Have any of you built this engine? If so, what did you think of it?
I'd appreciate any comments that you can offer.
Very respectfully,
Larry
Very respectfully,
Larry
