As already mentioned but also check the pneumatic cylinder for water contam its maybe a time out alarm.Try a loop prog using M43/M44 and check parameter is changing state parameter 62 is the lock time you could try doubling it.Its been a few years since i worked on these machines but it was usually the lock cylinder full of water that caused our probs. The switch nearest the turret is the unlock.
best wishes frazer
