JCSteam
- Nov 30, 2016
- 472
- 130
Hi,
Ive recently bought an ML4 lathe, been a machining novice ive just about got my head around what levers fo what ect.
However a couple of questions you might be able to answer for me.
1. Is it normal for the leadscrew handle not to be able to turn the leadscrew, when the change gears are engaged, or is this indicative that the headstock bearings are too tight? I can turn it and move the saddle, until I engage the first set of change gears, to the headstock, also theres a grinding on the first set of gears, this is with it just been turned by hand at the moment. My thinking is that its hearing up too high or the headstock spindle is too tight???
2. How can I tighten the backlash on the handles at the moment its at .0017thou on the topslide, and .0020 on the cross slide. Is this acceptable wear for a hobbiest??
3. Can I clean everything down with WD40 including the bedways? Ive already got some thick oil for the bedways.
Thanks in advance for any advice. They'll be more questions to come no doubt as I'm setting the lathe up
