My 1895 MERY engine
Discussion in 'Finished Projects' started by Philipintexas, May 16, 2012.
  1. Jan 9, 2019 #21
    Jack3M
    Jack3M
    Jack3M
    Jul 11, 2017
    283
    139
    I assume you meant automotive paint and clear? Heat may be an issue on them. I am considering powder coating. I saw one in purple powder coat and it was just awesome. Nothing wrong with ocd
  2. Jan 9, 2019 #22
    PhilL
    PhilL
    PhilL
    Sep 5, 2018
    47
    5
    Gender:
    Male
    Pa
    It was Krylon paint and clear. Both of them are too hard. I ended up using Rustoleum. It's softer and can tollerate hardware tightening and bumps.
    I did several coats of that with sanding between. Then I gave it a light buff to make it a uniform gloss.
    I've never done powder coat. I would be curious how that behaves compaired to Krylon or Rustoleum.
  3. Jan 10, 2019 #23
    karlw144
    karlw144
    karlw144
    Active Member
    Feb 20, 2010
    30
    1
    Phil, did you use rattle cans or bulk paint and thin it? I just started to machine mine and I’m already worried about painting.
  4. Jan 10, 2019 #24
    PhilL
    PhilL
    PhilL
    Sep 5, 2018
    47
    5
    Gender:
    Male
    Pa
    I mainly used rattle cans and masking. I did get the mini cans of brushable for the details. I've always used Rustoleum on my engines and didn't have any problems. This engine I first wanted a particular color I found in Krylon. That was my mistake. The enamel paints are just too hard for this use. Use Rustoleum and you'll be fine.
  5. Jan 10, 2019 #25
    Jack3M
    Jack3M
    Jack3M
    Jul 11, 2017
    283
    139
    As an itty-bitty side note, I have taken the rattle cans and sprayed small amounts of the paint into the cap for slight use like that.
  6. Jan 10, 2019 #26
    PhilL
    PhilL
    PhilL
    Sep 5, 2018
    47
    5
    Gender:
    Male
    Pa
    Agreed Jack. I've done that as well. I wasn't sure which method I was going to use for the majority of the painting. I was just happy to find the same color in both mediums. After I thought about it, that off white on the inside was brushed. Masking / spraying that would have been more painful.
  7. Jan 11, 2019 #27
    Jack3M
    Jack3M
    Jack3M
    Jul 11, 2017
    283
    139
    Well at oh dark thirty when couldn't go back to sleep after the pit stop and maybe I will begin on this. Recently had another project that was just giving me fits and was getting that attitude where I should not work on it. So worked on another for awhile then getting the light bulb for the first project, and completing it yesterday with the exception of 4 pieces of brass trim that needs to be bought. So...
Draft saved Draft deleted
Share This Page
