More progress on the Webster
Discussion in 'A Work In Progress' started by deere_x475guy, Feb 9, 2008.
  1. Feb 9, 2008 #1
    deere_x475guy
    deere_x475guy
    deere_x475guy
    Oct 26, 2007
    897
    11
    I finally got back into the shop today and finished what I could of the head and completed the cylinder. I needed to drill the oil cup hole in the cylinder, drill a 3/16" hole for the intake and exhaust and drill and tap 2 holes for 4/40 screws to hold the valve block assembly.
    For those of you that are familiar with this engine you will probably notice I had another brain fade today and drilled for the oil cup in the wrong place....DUH!!...no problem it's below where the rings are so I will just screw a plug in there. Not a show stopper, just something to remind me how humble I should be. ;D ;D
    Also I haven't cut the notch out of the side of the head for the side frame to bolt to. That's because I am going to vary from the plans a bit and run side frames up both sides of the head, change the crank, move the points and condenser to the other side of the piston rod.
    [​IMG]
    This afternoon I am going to cut the last gear I need and I will post some pics of that process.
  2. Feb 9, 2008 #2
    BobWarfield
    BobWarfield
    BobWarfield
    Dec 27, 2007
    1,151
    1
    Wow, that's really looking nice!
    BW
  3. Feb 9, 2008 #3
    chuck foster
    chuck foster
    chuck foster
    Jul 12, 2007
    704
    0
    i like the gear you are using for a washer to hold your rotary table down ;)
    waste not want not....
    chuck
  4. Feb 10, 2008 #4
    deere_x475guy
    deere_x475guy
    deere_x475guy
    Oct 26, 2007
    897
    11
    Good eye Chuck, that's one I scrapped early on.;)). If your mind drifts for one second your screwed..
Draft saved Draft deleted
Share This Page
Group Builder
