Making a Bourdon pipe shouldn´t be very hard either, basically it´s just a somewhat flattened nearly circular copper pipe. Could be bent with Cerrobend or equivalent. The problems I think would be in the pointer mechanism. A Bourdon tube has only little movement, so "gearing" that small movement up into a long pointer swing, that will be +/- accurately repeatable, will call for some watchmaking skills. Somewhat similar to building a test dial indicator (if you´re willing to sacrifice one, then you´re over halfway there ;D ).
Another awkward thing is to get a +/- uniform scale when calibrating. Meaning there should be clear separation between the (meaningful) pressure readings, so they won´t be all in almost the same spot on the scale. That depends mostly on the tube dimensions, length, wall thickness, etc. Might need a bit of experimenting ???
If you build one, use it often, and calibrate it many times during the first year, the readings are likely to shift quite a bit when the tube slowly work hardens.
If you want a dependable small gauge, it´s likely to be expensive, either directly on your wallet, or in the time needed to build and test several before you get it right.
