Hi
I needed a vice that would allow me to place work pieces flat on the mill table then clamp up tight. I'm sure most of you have something similar but I've not seen it posted so thought I would show how I did it. It took me a little over an hour to make and is designed to fit my X3 mill. First job was to cut 3 lengths of steel 7/8 square 6 3/8 long.
Drill 3 holes in the front fixed jaw to match the 3 T slots in the table.
Drill the same 3 holes in the back fixed jaw then turn through 90 degrees and drill 2 8.5mm holes.
Then tap out to10mm X 1.5.
The 2 fixed jaws bolted to the table with the loose moveable jaw at the side. " long 10mm bolts have been fitted. The 2 I have used are ford cylinder head bolts.
Holding a piece of flat bar with the loose jaw.
The 2 fixed jaws moved closer together using 2 adjacent T slots.
Setting up the fixed jaw square across the table.
Both jaws fitted across the table with the loose jaw in position.
How wide do you want it???
Holding a piece of flat plate.
The fixed jaws moved so that they use the front 2 T slots allowing the vice to overhang the front of the table. The 2 empty stud holes can now be used to bolt on additional clamping.
Holding awkward shapes is not a problem. The fixed jaws will turn slightly and the two bolts can be adjusted to suit.
The new vice compared to my existing vice.
Rich
Rich
